First post, by no1uknow
I installed and tried running dosbox. Everything is fine, cept as soon as i hit Alt-Enter, the screen turned black and then a white flash showed up on the screen with red green and blue lines going up and down. I hit alt-enter again and everything was fine. Scared me for a second that i damaged my monitor. Is this a common problem for others?
Im running Win XP Home on a Sony Vaio. 2.8Ghz
An ATI Radeon 9200 display adapter and a Samsung 17" flatscreen monitor. Runs at 1024x768, 75 hz refresh rate
Edited by mirekluza: I hate the topic titles ending with !!! ...
Reply 1 of 1, by MiniMax
Rank Moderator
Moderator
A search for refresh gives me this:
Full screen causes "signal out of range" with TFT screen
_________________
