Graphics and sound
First post, by Stormrider
I've tried DOSBOX with DFEND in two different computers, and Athlon 64 3000 and a P4 3000 and in both I'm experiencing the same problem. In full screen I get tearing in scrolls. If I enable double buffer I get perfect scrolls but the sound and music are jerky and stutter. I've tried several combinations of options and setups but I never get smooth graphics and correct sound at the same time. Any idea?
Reply 1 of 4, by eL_PuSHeR
Hello, welcome to the forums.
Which game(s) are you experiencing problems with? Tried increasing cycles and using dynamic core?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by MiniMax
Rank Moderator
Moderator
Keep a watch on your CPU utilization while using CTRL-F12 to increase your CPU-cycles (and CTRL-F11 to lower them). Don't let the CPU utilitization get over 80% - 90%.
Also trying adding some frameskipping to DOSBox (more about this in the Wiki linked in my signature).
_________________
Reply 3 of 4, by Stormrider
For instance Supaplex.
Reply 4 of 4, by eL_PuSHeR
Supaplex works fine for me under DOSBox 0.65 on my AMD Sempron 3000+
FullResolution=1280x1024
WindowResolution=1024x768
output=overlay
core=normal
cycles=auto
Intel i7 5960X
8 GB DDR4 (2100)
