First post, by GBonness
Can you start a 32-bit program from DOSBox by simply adding it to dosbox.config?
At the end of dosbox.config I have the following lines:
echo Mounting "F:\Ag Related\Farmacct" as harddisk drive C.
mount C "F:\Ag Related\Farmacct"
C:
# Start DOSPrinter to monitor temprint and print it out whenever it changes.
start DOSPrinter.exe /R /DEL temprint
# 'Frmactwp' is Farmacct for windows only printer
Frmactwp
# Unload DosPrinter
DOSPrinter.exe /U
exit
When I run the above in DOSBox, Frmactwp works correctly, but DOSPrinter doesn't seem to do anything. When I go back and open temprint manually with DOSPrinter it prints the report correctly. How can I get it to activate in conjunction with DOSBox?
(DOSPrinter is a 32-bit program to print a text file containing old EP2 printer control codes. Frmactwp is my own program (16 bit) written in QuickBasic.)
(Frmactwp.exe, DOSPrinter.exe, and temprint are all located in folder F:\Ag Related\Farmacct)
