First post, by ledzep228
ok here is what I have done so far....
daggerfall is installed in c:\games
mount c c:\games
mount d d:\ -t cdrom -ioctl
Error I get when I try to run DF: "looks like you inserted the wrong cd. please insert your daggerfall cd in your cdrom and try again"
The CD is in the D drive, and it is of course the correct CD. WTF is goin on?
Also, I have tried to mount an ISO for the D drive instead....same problem occured.
-ledzep
Reply 1 of 13, by MiniMax
Rank Moderator
Moderator
Installed how? How did it end up there?
_________________
Reply 2 of 13, by ledzep228
oops, it is in c:\dagger
i don't think where it is installed has any bearing on the issue i am experiencing
Reply 3 of 13, by MiniMax
Rank Moderator
Moderator
You might want to look into the -label option for mount.
_________________
Reply 4 of 13, by ledzep228
Your DosBox guide
60 seconds guide to getting your game to run in DOSBox
Does this actually work for you???
You say to make the directory c:\dosbox stuff\mygame
but I can't change the install path during installation.....
There is nothing in there about using -freesize command
so that there is room to install the game......without -freesize
the installer says there is no room available on the C:\ drive......
Either I am retarded or your guide is severely incomplete....
Reply 5 of 13, by wd
Rank DOSBox Author
DOSBox Author
That's where knowledge about the mount command comes handy, right?
See the dosbox README.
It's a general guide. Some points might differ with some games of course.
Reply 6 of 13, by ledzep228
I know how to use the mount command....
and I have read the ReadMe section on it several times....
The problem is trying to change the installation path WHILE the daggerfall installer is running. If you try to change the path it says "no drives available".
Reply 7 of 13, by wd
Rank DOSBox Author
DOSBox Author
Why should you change it? Install it on c: (that is the game will install into
your real "C:\DOSBox stuff\MyGame" if you mounted it as in the guide).
Reply 8 of 13, by MiniMax
Rank Moderator
Moderator
My vote is on option 1. It is pretty retarded to imply that a poster with +1000 posts to his name can't write a working guide.
_________________
Reply 9 of 13, by eL_PuSHeR
Please, let us keep civil and not resort to insulting.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 10 of 13, by keropi
and why do you want to run DaggerFall under dosbox? it works fine on my 2 xp machines...
Reply 11 of 13, by DosFreak
DaggerFall has issues with fast computer speeds of today and also DosBox has superior sound quality emulation.
Make your games work offline
Reply 12 of 13, by Freddo
DosFreak wrote:
DosBox has issues with fast computer speeds of today and also DosBox has superior sound quality emulation.
I'm sure you mean that Daggerfall has issues with fast computer speeds of today 😉
Anyway, the CD checker thingy in Daggerfall doesn't work well in DOSBox. But that doesn't really matter since it's easy to bypass. Instead of starting "DAGGER.EXE" to play the game, write "FALL.EXE Z.CFG".
Reply 13 of 13, by red_avatar
Wow, I forgot that - I was tearing my hair out trying to get it to detect the CD.
