Qbix wrote:what does dosbox say when you press ctrl-f5 in the console
It should say something!!!!!!!!!!!
(something like Capturing Screensh […]
(something like Capturing Screenshot to .....
or
Can't open capture dir for ......
if it doesn't then your os/windowmanager does steal the key combination.
Actually, nothing happens. Nothing is displayed nor new files are created. But this only happens when trying ctrl+F5. All other ctrl+F? functions seem to be working, including capturing to a wave file (which dumps the file to the captures directory i've defined).
Again, i find it strange that my window manager (i'm using Gnome on Ubuntu, by the way) is stealing just THAT combination.
I wanted to try capturing to a video file, but ctrl+alt+F? commands don't work as they open a tty window (is there a workaround for that?).
gulikoza wrote:I'm gonna ask the obvious...is screenshot support enabled in your build?
Whoa. Do i have to enable anything while building? I just did a ./configure, make and make install.
Prior to that, i did the same thing to the latest version of SDL. May i be missing some extra package from SDL?
Thanks again for your time, guys.
