Zero Critical Problem
First post, by Hazekel
I am having a strange problem with Zero Critical in XP. When I start it it does not appear to start at all, but when I check with CTRL-ALT-DLT I find that it is running as a "process" rather than an application. I confimed that my QT is up to date and I have "Windows 95 compatibility" checked (have also tried without it). The sound utility appears to work although when I run the RSX diagnosis it locks up after saying that everything is running fine! This game does work on another XP system I have.
Reply 1 of 1, by Hazekel
For those interested. The problem is compatibility with some Sound Accelerators. Turn off sound acceleration and the game should work but you will get an erroneous CD error. Ignore the CD error (it will play off CD even though it says it can't find CD) and play as usual.
