Need to disable mouse
First post, by shortstop4313
I'm running Dosbox 0.65
I have a old homebrew app where it will always crash if you use the mouse, it's a known issue with the program.
So I've been searching for a way to disable mouse support so that it won't crash.
Is there anyway to do this?
Reply 1 of 6, by ykhwong
Try a cvs build that includes "more parameters support for dos commands", then type "mouse /u" to disable mouse driver.
DOSBox SVN Builds
Reply 2 of 6, by shortstop4313
Hmmm, I'm having problems reading the notes from that thread...
None of them really mention quickly improved dos support.
Thanks for the point in the right direction, now that I'm rereading it's making a bit more sense.
Reply 3 of 6, by franpa
i hope this helps 😀 (you are looking for something different to what ykhwong said when you shouldnt)
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 4 of 6, by shortstop4313
I'm most likely not understanding what is said, then..
What am I to look for? I see a lot about different filter/shader sets, but...
Reply 5 of 6, by ykhwong
There is MOUSE.COM in drive Z, for example, if you use my build.
Reply 6 of 6, by shortstop4313
Tremendous, ykhwong! Thank you so much!
