Video driver
First post, by DutchBert
Since I installed DosBox it seems that there may be a problem with my video driver. I did get a serious conflict warning. I can't use packet writing anymore with Roxio's Drag To Disc, which program shows the "no recorder" message. Writing with Nero 6 Reloaded doesn't give any problem. Is there a solution for this?
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
are you certain it has to dos with dosbox ? and not with some new installed game ? (as it souns a bit like starforce problem)
Water flows down the stream
Reply 2 of 2, by DutchBert
I did also install Satellite TV For PC and its components, but after installing DosBox also problems with my HP PSC 2355 multifuntional printer did occur, which were solved by disconnecting it from the electricity.
