First post, by Snover
Is there a place where I can alter the default configuration of the VDMSound Launchpad? (It's really annoying to have to re-configure every time or set a "base" config file.)
Yes, it’s my fault.
Reply 1 of 6, by vladr
No. Defaults are in the code. 😀
See my reply to the "restore .vlp association" in the SourceForge "Help" forum as to how to easily reuse non-standard configurations.
V.
Reply 2 of 6, by Snover
Pleeease add an INI file!! I'm begging you! Don't hardcode those settings! (They're pretty poor settings to begin with 😉)
Yes, it’s my fault.
Reply 3 of 6, by vladr
Sorry, use the suggestions in the "Help" forum. I'm not going to add "configurable defaults", everybody would start messing with them and support would become a nightmare. There are other ways of reusing existing configurations that are even easier than going "Next, Next, Finish" through the Wizard.
V.
Reply 4 of 6, by Snover
What, you mean Copy Paste Rightclick Properties Change OK OK?
Yes, it’s my fault.
Reply 5 of 6, by vladr
No, I mean copy-paste alt+drag'n'drop .exe. 😁
Or drag'n'drop over existing shortcut
V.
Reply 6 of 6, by Snover
Yeah, 'cept I don't usually have VLP files around long enough for that to work for me. 😒
Yes, it’s my fault.
