very embarrassing
First post, by lundi-vendredi
Hi there,
I have decided to reinstall my old dos games which were sleeping in a floppy box at home... However, I got stuck at the very beginning:
How do you type a backslash \ ?
I have a swiss keyboard (qwertz) and I usually use AltGr ><
Well, I told you this was embarrassing.
Thank in advance for your help!
Gen
Reply 1 of 4, by Wintermute
In Dosbox you could also use "/" instead of "\". On German keyboards (don't know if Swiss is the same) you press the "-" key for this sign in DosBox.
Reply 2 of 4, by Zup
You may use keyb from FreeDOS inside DOSBox. I'm using it to get spanish keyboard.
I'm selling some stuff!
Reply 3 of 4, by lundi-vendredi
Thank you for your help.
I still have to try FreeDos, but my problem is momentarily solved.
\ is $ on the swiss french keyboard (yeah this one is really specially designed for 1mio people)
: is ö (shift é)
good to know that you can also use the / instead.
Thank you again!
Gen
Reply 4 of 4, by Zup
Not FreeDOS, only the KEYB program. It is DOSBox compatible, so you won't need to install everything.
