First post, by franpa
ok, i have mingw installed on my pc... the version that comes with zget (a program provided by nach for downloading and compiling ZSNES source)
if i download the source for dosbox... what folder do i type whatever it is thats needed to be typed to?
and what do i need to type?
😮 keep stuff simple please... and yes i already have paths setup for mingw... so no need to tell me how to do that.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 1 of 1, by mefistotelis
If you don't know the basics of programming (or at least how compilers works), it will be difficult for you to compile dosbox. Better use a precompiled package.
If you wish to compile it anyway, try searching the forum before writing.
a quick hint:
make clean
./configure
make
in the main directory of the source code package.
He who shouts loudest can only hear his own voice. Those with true knowledge listen to those with true faith. And those with closed ears never hear the swing of the reaper's blade.
- The Book of Cataclysm.
