First post, by Unregistered
Hello Ladies and Gentlemen!
I have installed VDMsound 2.04 and the Update plus the Launchpad 1.0.0.7 because I want to use the flight simulator programs "Airline Simulator 2" (AS2) and "Precision Simulator 1" (PS1.3a) with Windows XP Home Edition.
My problem is that every time I start one of this programs my joystick, a Microsoft Sidewinder Force Feedback Pro (the old one, NOT the USB) has a very limited range for left and right (aileron and rudder). The up/down and the throttle have absolutely no problems. The solution to solve this problem is that I calibrate the joystick with the program-included routine every time after launching this programs. But I do not need to save the vlaues because they are already stored correctly. So it seems that I have to do this calibration to "wake up" the joystick. After this wakeup process all axis work correct.
But I think there must be a way to avaiod this procedure.
I have tested it with the files joy3.map (the corrected one) and joy13.map.
Without the VMDS joystick emulation AS2 does not recognize the stick at all and PS1 hangs up during loading.
My system:
Intel Pentium 4, 2.53 GHz
512 MB DDR
120 GB Harddisc
128 MB DDR nVidia GeForce 4 MX 440 AGP 8x ViVo Graphic card
Creative Live Player 1024 Sound card
Has anyone an idea?
Thank you very much in advance to your answers!
Additional information:
I have had time to test it a little bit more. It seems that the throttle and the rudder will not be activated when starting this programs. I have to manually activate them within this programs and then the joystick works.
Christian
