First post, by eNTi
when i try to fire up ascendancy (or the setsound.exe - auto detect hardware), dosbox segfaults:
(gdb) bt#0 0x00000000004782db in ?? ()#1 0x0000000000479108 in ?? ()#2 0x00000000004704bc in ?? ()#3 0x0000000000420cec in ?? ()#4 0x0000000000406fc8 in ?? ()#5 0x0000000000406f6a in ?? ()#6 0x000000000040848d in ?? ()#7 0x00000000004f1f09 in ?? ()#8 0x00000000004ef11a in ?? ()#9 0x00000000004ebe9c in ?? ()#10 0x00000000004ed31c in ?? ()#11 0x00000000004ed16f in ?? ()#12 0x0000000000498d12 in ?? ()#13 0x00002b0cacb0f394 in __libc_start_main () from /lib/libc.so.6#14 0x0000000000406ea9 in ?? ()#15 0x00007fffff0dec28 in ?? ()#16 0x0000000000000000 in ?? ()
the backtrace doesn't look too helpful, i've included it non the less.
i can run other games. i played eye of the beholder yesterday, with sound and everything.
a friend of mine played ascendancy with dosbox on windows and said, it worked quite well (with sound and all). maybe i'll try that to, so i can rule out a hardware problem.
- Linux enti 2.6.18-gentoo-r3 #1 SMP Tue Nov 21 11:30:12 CET 2006 x86_64 AMD Athlon(tm) 64 Processor 3500+ AuthenticAMD GNU/Linux
- X Window System Version 7.2.0
- gcc (GCC) 4.1.1 (Gentoo 4.1.1-r3)
- KDE 3.5.5
- dosbox 0.65
- nvidia-drivers 1.0.9746 (GeForce 7900GT)
- alsa-lib 1.0.13 (Audigy 2 ZS)
