No Music, but sound. o_O
First post, by Soul Reaver
First of all, I've posted this problem on another forum already but they weren't able to help me. But this one seems more directly geared towards what I need to know, so I'll ask here.
Anyway... I'm really stumped, not to mention rather disappointed.
I've been trying to play some of the old classic games I have, including Doom 2, Ultima Underworld and Hexen... and I've discovered something rather worrying.
For some reason, none of these old DOS games will play music, even though the sound works fine!
I'm playing them in a Windows 98 environment without actually restarting in DOS mode or anything (I don't think my sound card has any DOS drivers anyway).
My sound card is a Creative Labs Sound Blaster Live!
The music in these games is always somewhat midi-ish, but this card plays midi music fine on webpages or over WinAmp - it just won't play it in the games!
However, the sound effects, such as speech, gun blasts, sword swings etc all work flawlessly. I can't work out why the digital effects work but the music doesn't. I've tried numerous different cards and settings in the sound-setup programs of these games, but all have the same problem.
To make this even stranger, I KNOW this card can work - it worked in the past. It's stopped working since I've formatted my HD though and reinstalled everything. I can't figure out what might be different now to make it stop working.
If anyone has any idea why this isn't working, please let me know - I really want to play Ultima Underworld again!
Thanks...
"Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life"
- Terry Pratchett, 'Jingo'
Reply 1 of 7, by Nicht Sehr Gut
Originally posted by Soul Reaver First of all, I've posted this problem on another forum already but they weren't able to help me. But this one seems more directly geared towards what I need to know, so I'll ask here.
Another forum on another board? or here?
For some reason, none of these old DOS games will play music, even though the sound works fine!...I'm playing them in a Windows 98 environment without actually restarting in DOS mode or anything (I don't think my sound card has any DOS drivers anyway).
Hrmm... Just remember that each of these may need individual troubleshooting.
Well, remember that MIDI in DOS games was originally intended for a "real" MIDI device. What modern Windows do, is redirect that output to a software/hardware wavetable.
Wild guess? You switched between VXD and WDM drivers for your soundcard. When I used to have this card, I remembered my compatibility would "switch around", depending on whether I was using VXD or WDM drivers. There's some debate as to which is more preferable.
You might take a look at:
http://reconstruction.voyd.net
As far as DOOM and Hexen are concerned, start using the Win9x/NT ports available at http://www.doomworld.com/ports/windows.shtml
If your system is capable, I recommend the "Doomsday" engine (JDOOM, JHeretic, JHexen) from Jaakko Keränen.
His homepage is: http://www.doomsdayhq.com/
Reply 2 of 7, by HunterZ
Just some things to note:
- The SB Live doesn't have a real OPLx FM chip on-board, so if you're trying to do Adlib/Soundblaster music in your DOS games, they'll sound like crap because it uses poor quality emulation in Win9x
- If you try to do General MIDI/MPU-401 music, it uses a primitive Ensoniq software wavetable synthesizer with a 2 megabyte Ensoniq "waveset" instrument bank (look for a .ECW file buried in your Windows system folders - that's what it's using)
In short, Creative's support for DOS on the SB Live in Win9x and pure DOS is not very good. I've been enjoying DOS games much more using WinXP and VDMSound because I can use SoundFonts for MIDI and I can get much better OPLx emulation.
*walks off grumbling about Creative Labs*
Reply 3 of 7, by Snover
Ensure you are using "MPU-401" instead of "AdLib/SoundBlaster" for the MIDI interface in those games.
Yes, it’s my fault.
Reply 4 of 7, by Soul Reaver
Hmmm... how do I change this? And if I don't have a MPU-401 option, how do I get one?
I thought I knew where to change it (the MIDI tab in the Control Panel -> Multimedia section) but unfortunately it doesn't seem possible to change it there. At least, there's no MPU-401 written anywhere there.
I don't THINK they do... these games all used to work with Midi and now don't, so I assume the problem has a common cause.
Sorry I didn't make that clear enough... I meant on another board.
I don't THINK that's it... I haven't installed any different drivers to my knowledge... I think I installed the same drivers from the same disc as before.
Reply 5 of 7, by gidierre
Generally, HunterZ is absolutely right when he talks about "enjoying DOS games much more using WinXP and VDMSound " vs. a dos session, but aside from this
well I also have a SB Live and those dos drivers exist.
Don't you have the drivers disk ?
In any case I have it, and yet was unable to install them (I mean the dos ones) off the cd because of an IRQ conflict, which not even editing the bios settings could fix.
So I searched and found one standalone "sblive2sb16.zip" archive and finally using a boot disk from Win98 (for this purpose it can't be WinME because of an emm386 mismatch between the Live dos drivers and the Millennium ebd) there was a way of bypassing the IRQ problem and having those drivers eventually installed (and initialized !!).
So if you want, why not try it 😀
Reply 6 of 7, by HunterZ
The Windows MIDI settings will have NO effect on the DOS emulation for the SB Live, because as I said, the SB Live uses an Ensoniq software synthesizer instead of the Windows MIDI device. Yes, it's stupid, but that's what they did.
You have to choose MPU-401 or General MIDI or whatever in the particular DOS game you're trying to run.
Reply 7 of 7, by Nicht Sehr Gut
Originally posted by Soul Reaver I don't THINK they do... these games all used to work with Midi and now don't, so I assume the problem has a common cause.
Don't assume. While it's quite possible that it's solely a middle problem, it's just as possible that it's a combination of other issues.
Ok, I was looking for other people's conclusions. Can I presume they came up with nothing?
Well I no longer have the card to verify it, so we need a SB Live user with some experience on this.
