62, 63, 65 terminate
First post, by kapkao
previous 3 versions of dosbox terminate without error.
65 opens a status window then *poof!*
D875PBZLK mainboard
p4 2.6 ghz
1 gig 400 mhz sd/ddr ram
radeon x800 xt agp 8x 256mb internalDAC
SBlaster Audigy
Winxp/sp2
Directx 90b
ATI Catalyst 7.1x
Read readme, multiple times actually
stuff
Reply 1 of 13, by MiniMax
Rank Moderator
Moderator
Is this just from starting DOSBox? Before you start a game or anything? How do you start DOSBox?
_________________
Reply 2 of 13, by kapkao
yes, yes, and by clicking on the start menu shortcut or just the exe itself.
stuff
Reply 3 of 13, by mf2hd
maybe dll corrupted or wrong(?)
Reply 4 of 13, by kapkao
WHich one/type?
stuff
Reply 5 of 13, by kapkao
kapkao wrote:
WHich one/type?
actually, knowing the dependencies of Dosbox would simply rock! 😢
stuff
Reply 6 of 13, by wd
Rank DOSBox Author
DOSBox Author
Get a dependency walker then, though i doubt this will solve your problem.
If it crashes that early it's most likely something with sdl. Try upgrading
your graphics card drivers, change the output= in dosbox.conf or try
replacing sdl.dll with an older/newer one.
Reply 7 of 13, by kapkao
A which? :p
(I'll look it up later)
I think exescope can find these, actually. Either way...
Lotsa crap gets messed up, over the years.
And my crap works most of the time, so if I could get DOSBOX to work without reinstalling XP I'd prefer it.
I tried 62, 63, 65, so I doubt it's old/new code.
I got 63 to work a couple years ago so I'm guessing it's what mf2hd said...
edit quote tag
edit2... welll maybe it is something with the grafix card. that's the only MAJOR difference between a working dosbox for me.
I had a geforce 6200 before going to an x800
stuff
Reply 8 of 13, by mf2hd
I've thought something related to sdl.dll or other dll that dbox wants (sdl_net.dll,libpng...), these ones are in dbox directory.
I had a similar problem with some dbox compiled by myself, it works fine with a sdl but with other ones it crashed at start up (status window shows an incomplete message: "CONFIG:Loading primary settings from con".
Try this (I don't have an xp english version so don't know if the names are the same):
right-click on dosbox.exe ->Proprieties -> Compatibility -> set "win95" or
"win98/Me".
On my system this setting locks the "status window" on exit, so I can see the errors . After this, the dosbox.exe must be terminated by the tasks manager (ctrl-alt-del).
Reply 9 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
could you post all your environment settings ?
(startup cmd.exe and type set)
Perharps there are more places for them, but I leave that to someone with winXP installed
Water flows down the stream
Reply 10 of 13, by MiniMax
Rank Moderator
Moderator
But not from a CMD-window?
Try starting DOSBox with
C:\> dosbox -noconsole
and watch for the files stderr.txt and stdout.txt appearing in the working directory.
_________________
Reply 11 of 13, by kapkao
ok,nvm
stuff
Reply 12 of 13, by kapkao
C:\Documents and Settings\xxxxxxxxxx>set ALLUSERSPROFILE=C:\Documents and Settings\All Users APPDATA=C:\Documents and Settings\x […]
APPDATA=C:\Documents and Settings\xxxxxxxxxxxxx\Application Data
CLIENTNAME=Console
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=xxxxxxxxxxxxxxx
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\xxxxxxxxx
LOGONSERVER=\\xxxxxxxxxxxxxx
NUMBER_OF_PROCESSORS=2
OS=Windows_NT
Path=C:\Perl\bin\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Pro
gram Files\ZipGenius 5;C:\Program Files\UltraEdit;;;C:\Program Files\cvsnt;c:\Pr
ogram Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\ATI Technologie
s\ATI.ACE\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=15
PROCESSOR_REVISION=0209
PROMPT=$P$G
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\xxxxxxxxxx\LOCALS~1\Temp
TMP=C:\DOCUME~1\xxxxxxxxxxx\LOCALS~1\Temp
USERDOMAIN=xxxxxxxx-63B2IXUE
USERNAME=xxxxxxxxxxx
USERPROFILE=C:\Documents and Settings\xxxxxxxxxxx
windir=C:\WINDOWS
Reply 13 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
I don't see anything wrong here.
Do you have the motivation to run some test executables to see how far dosbox comes ?
