pdosbos problem
First post, by bugmenot
Hi,
I come to try pdoxbox (dosbox for pocket pc). I come here because I believe that the development of pdosbox is stop, but maybe here someone can help me.
I have not the keyboard which displays on pdosbox so I have difficulty throwing(launching) one games above.
But when I arrive (by the script of dosconf), everything the games that I tested indicates that I have not enough memory(report). (My disc is almost empty). Know you how I can make?
Reply 1 of 1, by Xelasarg
I can't help you with your specific problem (apart from the usual RTFineM 😊 advice), but you should use n0p's DOSBox port anyway. It's much better in terms of compatibility, speed and configurability.
Get it here:
http://n0p.averest-k.ru/?DOSBox_PPC:DOSBox_0.63:Downloads
You'll want the XScale build for any PPC running Windows Mobile 2003 or later.
This port works pretty well, and the documentation is also quite good. The default memsize of 4 MB should be more than enough for any games that can be run on PPC DOSBox.
