First post, by shachark1
the list of those games are:
1.jones in the fast lane cd - imgmount work fine but mouse dont work without mountiso problem with speech files
2. return of the phantom cd - with or without imgmount problem with install
3. kgb cd - imgmount work fine but no music & speech or without imgmount
4. alien incident - problem with music & speech in imgmount or without
5. inca 1+2 cd - problem with the music& speech imgmount or without imgmount
6. lost in time 1+2 cd - problem in music & speech with or without imgmount
7. jack the ripper cd dos version - problem with music & speech with or without imgmount
8. king quest 8 direct3d problem
also updates dont work
if someone can help it will really help me
thenk you
Reply 1 of 2, by DosFreak
I do not have the CD versions of any of these games but if they use CD Audio and your only mounting a .ISO then the CD audio isn't included. .ISO is only a data format not RAW. You'll need to create a .BIN/.CUE of your CD's if you want to hear CD audio with a CD mounted using imgmount.
Also the only way I've ever been able to hear CD audio in DosBox is by creating a .BIN/.CUE and imgmounting it. Using Daemon Tools or just using the physical CD I've never been able to use CD Audio. No big loss since I'd rather DosBox handle mounting the image with an imgmount command rather than tying up Daemon Tools with yet another mounted image or having to deal with the PITA of using a physical CD.
Make your games work offline
