First post, by Unregistered
i had tried to search about this ................ i ' ve tried to play under win 2000 following your children xxxxxx but nothing.
can you help me??
andrea
can you help me??
andrea
Okay for Duke3D read this thread: showthread.php?s=&threadid=1402
As for Shadow Warrior: What's the problem?
Originally posted by Unregistered i had tried to search about this ................ i ' ve tried to play under win 2000 following your children xxxxxx but nothing.
Andrea, you're killing me...we need DETAILS. "but nothing" doesn't tell me anything.
For Duke3D you might try one of the early experimental ports (listed on thread link DosFreak gave you...).
As for "Shadow Warrior" start from the beginning....after installing it. Configure it to run with no sound, no music, and 320x200 resolution. Does it run properly with those settings?
My children are doing WHAT?! SIX X's!? DEAR GOD! that's TWICE THE RAUNCHINESS! Those sick bastards!
... yes, it's that kind of day.
Yes, it’s my fault.
thanx to dosfreak for the help...........with the new win 32 port version of duke 3d it runs in a while !!!
GREAT!!!!
now i wanna know if there's something good (like as 4 duke) for shadow warrior.
i have downloaded a shareware version of the game from Kazaa
but the sound doesn't work (but the game works very good!!)...........there isn't a SWwin32port???
do u know how i can shift from the shareware version i downloaded to the complete version (patch or web site where i can download it in a full version)??
thanks a lot
andrea tagliasacchi
wrote:...i wanna know if there's something good (like as 4 duke) for shadow warrior.
No. There isn't.
Again, no, there isn't. And don't expect one. Only the Duke source has been released. The Shadow Warriors probably never will be.
That's illegal. Go find a copy on eBay or somewhere similar.
Yes, it’s my fault.
how i can configure shadow warrior sound options under dos 6??
thanx
Everyone hide all the sharp objects. The admin has flipped-his-wig again. Admittedly, this can be difficult to ascertain at times. Especially considering how bewildering he is during "normal-wig" status.
I always knew that toupee's were trouble...
Do you not get it? We can't just tell you that, we need to know what kind of sound card you have first, at the VERY LEAST.
Yes, it’s my fault.
Hey, man, my hair is all mine! *brushes hands through hair as it falls to the floor*
...well, it was, before I went bald.
Yes, it’s my fault.
Originally posted by Unregistered how i can configure shadow warrior sound options under dos 6??
You mean by using an actual install of DOS 6? or just a bootable DOS 6 floppy disk? If you mean an actual install of DOS 6, then the instructions for DOS audio should have come with your soundcard and it's software.
BTW, I merged the two threads you created back into one. Also, you never told me what happened when you configure it to run with no sound, no music, and 320x200 resolution. Does it run properly with those settings?
Originally posted by Snover Hey, man, my hair is all mine!
Enjoy it while it lasts. One day you'll start getting regular visits from the "Hair Fairy" as she adds you to her collection.
....one day I'm gonna strangle that little tart...
OS:
DOS 6.0 (not from boot disk!!)
hardware:
c-media 8738 sound card, i have found and installed the dos drivers and a attached patch to resolve some pci audio problems.
software test:
the game runs with no sound, no music, and 320x200 resolution
perfectly but i if i select a vesa video mode it tells me that there si an error and that the hardware can't support this mode.
to what regards the sound settings i'm not able to set the sound blaster settings (i suppose i have to set up this sound card, it's true??).
to give you more details i paste here what there is in my dos autoexec and config file.
AUTOEXEC.BAT
LH /L:0;1,42384 /S C:\DOS\SMARTDRV.EXE
@ECHO OFF
PROMPT $p$g
PATH C:\DOS
SET TEMP=C:\DOS
c:MSCDEX.exe /D:MSCD0000
MODE CON CODEPAGE PREPARE=((850) C:\DOS\EGA.CPI)
MODE CON CODEPAGE SELECT=850
LH /L:1,16208 KEYB IT,,C:\DOS\KEYBOARD.SYS
C:\mouse\MOUSE
C:\PCIAUDIO\SETAUDIO
SET BLASTER=A220 I5 D1 H5 T4
C:\PCIAUDIO\C3DMIX /MFF000 /FFF400 /WFF400 /LFF4FF /EFF4FF /AFF4FF /D00400 /CF0470 /330000 /O00000
CONFIG.SYS
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE NOEMS HIGHSCAN
DEVICE=C:atapycd.sys /D:mscd0000
BUFFERS=15,0
FILES=30
DOS=UMB
LASTDRIVE=E
FCBS=4,0
DEVICEHIGH /L:1,12464 =C:\DOS\SETVER.EXE
DOS=HIGH
COUNTRY=039,850,C:\DOS\COUNTRY.SYS
DEVICEHIGH /L:1,15824 =C:\DOS\DISPLAY.SYS CON=(EGA,,1)
PCI SOUND PATCH DESCRIPTION
We found that there are some EPIC DOS games can not detect PCI audio. This is due to these games using instruction loop as time counter not a real constant period. In high speed CPU PC, the loop time become shorter. That is reason that games can not detect PCI audio. If you meet this problem, please run patch program to fix.
All of fixed files will backup to *.old.
thanx to you all and sorry for my english !!
Different unregistered here.
The EPIC patch is probably not necessary.
What kind of video card do you have? maybe the crash is related to that.
my video card is a SIS 630/730 but i have no problem to play with low resolution!!
but i wanna hear something when i play!!!
i have two other old dos games warcraft 2, syndicate (1 and wars) but i'm not able to configure those f""""g sound settings!!
thanx to u all
andrea
Whoa, calm down.
Let's try to get sound working first, guys.
Then, when it works, we can help get high-resolutions working. AdvanceVBE might come in handy.
Originally posted by Unregistered OS: DOS 6.0 (not from boot disk!!) hardware: c-media 8738 sound card, i have found and inst […]
hardware:
*ack* Andrea, you really are killing me. First off, 8738 DOS audio support is terrible. I know, I used to have to deal with it for months. Getting any DOS game running in a "true" DOS mode almost never worked properly. Also, as far as I know, the DOS drivers out there only run in the DOS mode of Win9x; not DOS 6. I could be wrong, but considering how bad it's DOS support in Win9x was...I doubt it.
This is why I recommend Win95B for people trying to run old titles that won't work in Win2000 or XP. It has the maximum amount of compatibility for older game titles (DOS and Windows games). Even if it fails in the "true" DOS mode, you at least might have a chance to get it working with audio when running in Windows mode.
...the game runs with no sound, no music, and 320x200 resolution...
Good. That confirms that you have a good, working install of the game. Something (as I have come to learn...) we cannot presume to be true.
...but i if i select a vesa video mode it tells me that there is an error and that the hardware can't support this mode.
NOT good, at all... By the way, you didn't tell us what kind of video card you are using.
I will tell you that support for VESA in DOS or Win9x is much better than in XP. So if it doesn't work properly in DOS6, that is a bad omen...
...to what regards the sound settings i'm not able to set the sound blaster settings (i suppose i have to set up this sound card, it's true??).
You should use the game SETUP program to match your soundcard settings.
In your case:
means to use the following settings in Shadow Warrior:
Current Address [ 0x220 ]
Current Type ( Sound Blaster Pro )
Current Interrupt [ 5 ]
Current 8-bit DMA [ 1 ]
Current 16-bit DMA [ 5 ]
(if SoundBlaster "new" doesn't work, try "old", if that doesn't work, try "SoundBlaster or compatible")
That doesn't apply to "Shadow Warrior". The patch for PCI audio problems is from Ken Silverman's website here: http://www.advsys.net/ken/swsndfx.exe and must be run within your Shadow Warrior game directory.
Just try to be patient. As you may have figured out by now, DOS games can take a lot of work to get them running sometimes...
u tell me that i have to use a win95b SO version but i haven't the installation CD.
win 98se would be a good SO??
it supports games like warcraft 2 , syndicate and shadow warrior???
and over the other thing:
why the sound setup of a lot of games running in dos 6.0 if i set the SBlast settings (as you tell me) tells me that the sound card can't be find on the selected port??
maybe that the 8738 drivers for dos6 doesn't work for nothing???
thanks andrea
sorry i've forgotten to ask u a thing !!
how i can configure the network settings in my university labs to play duke with other 4 or 5 guys ??
i posted an help request on a newsgroup (alt.binaries.somethingelse) asking if i need something like KALI (i hate that program doesn't exist a correct illegal serial code)
but they tell me that i don't need it ..........and i'm so happy.
but i don't want to lost hours setting up the game so if anyone of you made this thing before it would be great if he tells me how to configure!!!
bye andrea
