First post, by jdziedzic
Ever since switching my computer over to Ubuntu Linux after a fateful hard drive crash, I've been having problems with the IPXNET utility in DOSbox. Every time I either try to start a server or connect to a friend's computer, DOSbox gives me the message "Tunneling server failed to start/connect." Single-player games through DOSbox are no problem for me on Linux, so DOSbox in general works fine for me, it's just IPXNET that's giving me problems.
I played countless multiplayer games of Master of Orion 2 when I was running Windows XP and never had a problem. I used the guide at http://masteroforion2.blogspot.com/2006/05/dosbox-guide.html to configure DOSbox, and I've helped other people set up MOO2 multiplayer games with the same guide. I've walked through those steps at least 3-4 times on my new OS, but I'm still having the same problem.
Keeping in mind that I'm pretty new to Linux and know next to nothing about networking, can someone please give me an idea of where to start troubleshooting?
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
did you select a port number above 1024 ?
(you should)
Water flows down the stream
Reply 2 of 6, by jdziedzic
Wow. That was surprisingly painless. Thanks! Also, your avatar is extremely hypnotic.
Reply 3 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
thanks.
You might want to know (it is mentioned somewhere in the readme)
that regular users (non-root or other uid 0 users) can't open ports under 1024 in listen mode under linux.
Reply 4 of 6, by wd
Rank DOSBox Author
DOSBox Author
Oh there's another avatar around here that is much more, um, hypnotic...
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
do you want that other avatar at fullscreen ? 😉
I got the episode somewhere.
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
At least seems to be the source of even more avatars...
