First post, by Chmielu
i run turbo c++ and i cant write #
what can i do with this ??
Reply 7 of 14, by DosFreak
You can use a USB keyboard with DosBox on a real PC. Theoretically it should work for Pocket PC but I've never tried it. If your Pocket PC works fine with the keyboard then so should DosBox.
Make your games work offline
Reply 13 of 14, by MiniMax
Rank Moderator
Moderator
I am afraid there is not much to do about the text fonts. Here is a screenshot from v. 0.61 of DOSBox PPC:
http://n0p.averest-k.ru/?DOSBox_PPC:DOSBox_0.61:Screenshots
But I could be wrong...
Maybe this version is better? http://www.pocketwall.com/pDOSBox/
_________________
Reply 14 of 14, by zoom
This post was from a while back. Have you heard anything recently regarding whether a USB keyboard is used on pocket PCs?
A separate USB keyboard can be attached to a laptop for larger keys.
