Real Hardware available
First post, by clownxx
Hey, i found DosBox this moment. I'd like to emulate Dos on a Windows PC. Is it possible to use the parallel port, an if, is the emulatetd Paralelport mapped to the real one??
Thanks and best regards.
Reply 1 of 2, by MiniMax
Rank Moderator
Moderator
I am not sure about the official status of parallel port support in DOSBox. I believe some functionality is supported in v. 0.65. If you need more than that, try one of the experimental versions listed here:
DOSBox SVN Builds
What do you need the parallel port for??
_________________
