First post, by MiniMax
Rank Moderator
Moderator
I have noticed at least 2 games (Sim Earth + Railroad Tycoon) where using a scaler does not result in an increased window size.
When I read the comments in dosbox.conf it says:
# scaler -- Scaler used to enlarge/enhance low resolution modes.
Low resolution modes? Is that anything not VGA (640×480)? Will scalers not work with games that already run with a "high-res" 640×480 mode?
My current workaround is to use windowresolution=..... with overlay if I want to get a bigger window.
_________________
Reply 1 of 3, by ykhwong
Yes, software scaler works basically with only low resolution. Using my build, try a parameter -forcescaler to force the scalers work in any resolution. (only normal/rgb works, however)
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
Thanks ykhwong. But it leaves me curious as to why the scalers are not forced in all situations? If I put it in my config, then it is because I 1) want a bigger window, 2) possible some smoothing of the results. I don't like DOSBox/the scalers to ignore my requests.
_________________
Reply 3 of 3, by ykhwong
Some high resolutions like 1024x768 may require lots of reosurces if scalers are always forced in any res, and some people may dislike it due to a decline of speed or unsupported, too high resolution (e.g. Normal2x : 1024x768 * 2 = 2048x1536.)
