First post, by The Coop
- Newbie
Greetings folks.
I've been using DOSBox for a quite a while now, and enjoying a lot of the older games that I own because of it. So first, let me give a big kudos to the folks making this program work so well, and an equally big thanks for making it in general so I can enjoy the likes of Descent, Wolfenstein 3D and the old D&D RPGs.
However, I've run into a nasty problem with an older Psygnosis game called Pyrotechnica. I can get the game to install from the CD without a problem, but I have no sound... at all. No music, no sound effects, and to top it off, the game refuses to recognize any of the sound emulation of DOSBox. Every audio config file in Pyrotechnica's folder is empty, save for a few letters (like for the Sound Blaster file, it just says "sbl"). It tells me to make a boot disk so that the game can grab the needed info from the autoexec and config "bat" files, but when I try to make it, it tells me the disk isn't usable (despite being able to use it outside of DOSBox). I've been trying for the last two weeks to get the sound working in this game, and I'm close to my wit's end with it.
I done several searches, and only found that according to two posts, the game runs just fine with sound (one post mentioned Adlib and SB for music and FX), but no commentary on how to get the sound working. Has anyone gotten the sound for Pyrotechnica to run in DOSBox, and if so, how?
Here's my general PC info in case it's needed...
XP Home Edition
GeForce 7800GS (AGP)
Realtek AC97 Audio
DOSBox .65
P4 3.00E GHz (HT)
1GB of PC3200 RAM
I also have the following lines at the bottom of DOSBox's config file...
loadfix -f
mount f f:\ -t cdrom
mount c c:\Games
mount a a:\ -t floppy
