Planet's Edge
First post, by Unregistered
Hello,
My system is a Athlon XP 1600+ and WinXP.
I would like to play Planet's Edge (again, 'cause it's great). Adlib sound is working perfectly, but I've got a big speed problem. When I'm in space (leaving the launch pad from homebase), it's so fast that I can't do anything. The internal spped patch in VDMS doesn't work as 'CAP Dos timer frequency' doesn't work, too...
Can you give me some suggestions, please?
Many thanks in advance...
Get PE here:
http://www.the-underdogs.org/game.php?name=Planet's+Edge
Reply 1 of 4, by Snover
Hmm, yeah. That'll happen. Um, have you tried running it in DOSBox? I bet it's a DPMI game though, hmm... Well, you might have to wait, there isn't much to be done about games using processor clock speeds to perform things.
Yes, it’s my fault.
Reply 2 of 4, by Nicht Sehr Gut
Originally posted by Unregistered My system is a Athlon XP 1600+ and WinXP.
I would like to play Planet's Edge ... but I've got a big speed problem. When I'm in space (leaving the launch pad from homebase), it's so fast that I can't do anything. The internal speed patch in VDMS doesn't work as 'CAP Dos timer frequency' doesn't work, too...
Well the CAP really isn't meant as a replacement for the various slow-down programs out there. Slow-down programs in general aren't a very good solution.
Fortunately, this should be pretty easy to handle by DosBox. You might have to increase or decrease the # of "cycles" that it's using to get the right speed. Be sure to read the ReadMe file that comes with it.
Originally posted by Snover I bet it's a DPMI game though, hmm...
Fortunately, no. It's actually a 286 game. Doing some basic tests seemed fine.
Reply 3 of 4, by Unregistered
Unlimited thanks, Nicht Sehr Gut.
DosBox is a real treasure. It works and with adlib... Thanks... Yeah, yeah, playing this great game again...
ThnxThnxThnxThnxThnxThnxThnxThnxThnxThnx
Reply 4 of 4, by Nicht Sehr Gut
...and there was much rejoicing...yea.
