Originally posted by Unregistered Hi everybody
Hello. Please follow the posting guidelines and give us your system specifications like the processor, memory, video card, etc... Even if it seems irrelevant...it's frequently the key to troubleshooting.
I try to let run "robin hood" from SIERRA (1990)
As in Robin Hood: Conquests of the Longbow by Sierra, (1993)?
I instal VMS sound on the robin directory and run it. The message is : it has run successfully (something like that 😀
You ran it on the game's executable or batch file, not the game's directory, right? You can't "run" a directory.
Also, you didn't actually install VDMSound inside the game directory, did you?
... but after that i clicked on the robin icon to run the game and the same message as before vmssound appear : "unable to initilaze your audio card"
This not a VDMSound problem:
Read the first question on this FAQ:
http://www.queststudios.com/FAQ/audiofaq.html
It's almost a certainty that the answer for you is #4.
I have a sound card integrated on my motherboard.. is it that , the problem ?
While integrated audio hardware tends to be very poor with DOS games (especially in DOS or Win9x), it's probably not related in this case.
If your game version is v1.0, try this patch:
ftp://ftp.sierra.com/pub/patches/pc/lbpat.exe
Start it and it will create the following files:
140.SCR
140.TEX
1535.TEX
180.SCR
README.BAT
README.TXT
Backup those files in your game directory (just in case), then copy the replacement files into your game directory.
If you still can't get SB audio, try using v3 of the GoSierrapatch.
If you're still not getting audio, you might try it with DosBox. Technically it should be possible (can run on a 286), but many Sierra titles seem to have problems on DosBox.
