First post, by dreambleed
I have and old russian programm which i really need to use...it launches perfectly but i see only wicked symbols - not the russian letters....Could somebody telll how it could be cured?
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
I assume it only worked on russian-layouted dos versions? Then you need
codepage switching (next dosbox version should be capable of this).
Reply 2 of 3, by ErikGG
Hi wd,
I was wondering, are you talking about the 0.66 CVS version?
If so, does a user need to switch it manually or does DOSBox detect the need for a codepage switch?
EDIT : Never mind, my bad (Use KeyB), actually thought it where two separate issues keyboard input and character visualisation.
Erik.
Read the new FAQ.doc
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
Yep keyb cares about codepage switching (that is it integrates those
mode con cp xx things) as they're closely linked to keyboard layouts.
