Discworld 2 VDMSound
First post, by Owskie
OK after many attempts i FINALLY GOT discworld 2 running. But i have sound stuttering, so i tried running it with standard VDMS. Discworld cannot locate the discworld CD tried with launch pad Discworld cannot locate the discworld CD.... so im baffled on what i can do to get this to run.
Any suggestions?
im attaching my AUTOEXEC.VDMS file. i think i could have screwed something up in that earlier.
please take a look
Reply 1 of 3, by vladr
Did you enable CD-ROM support in launchPad?
V.
Owskie wrote:
OK after many attempts i FINALLY GOT discworld 2 running. But i have sound stuttering, so i tried running it with standard VDMS. […]
Any suggestions?
please take a look
Reply 2 of 3, by Owskie
yea i think i did i uncommented some line, launch pad doesnt work for me.....any who i got it working with VDMSound. Problem is the intro movie and other important scenes still ahve sound stuttering.
Reply 3 of 3, by DRECK
1. Check the "Myvdmsfiles.txt"!
2. My only way to install Discworld 2 is here
Scroll down for "Yeah I know the..."
showthread.php?threadid=218&pagenumber=3
3. Then use "Run with VDMS"(without Music NOTE) on SETSOUND.EXE!
Choose Soundblaster 1 or maybe the SB PRO! But first test "Soundblaster 1"!
Do not select SB16!!!!!!!!!!!!!!!!!!!
Autodetect and save! And then there should be a DIG.INI file 😉
4. USE "Run with VDMS"(without music note) on DWB.exe or DWB.bat!
