compiling problem of franpa
First post, by franpa
er, i get a no makefile was found error and i've tried "make" in both the source main folder and the src subfolder.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 1 of 131, by leileilol
Did you ./configure ?
long live PCem
FUCK "AI"
Reply 2 of 131, by franpa
says that aint a valid command. (compiling from windows and not a terminal)
edit: i see, i may know what to do... just lemme check something...
my website
Reply 3 of 131, by franpa
nope, i cant compile it -.- yet i can compile zsnes fine and dandy, why is there no makefile.ms? what is this ./configure for? do i need a path to somewhere for ./configure to work?
my website
Reply 4 of 131, by wd
Rank DOSBox Author
DOSBox Author
There's a precompiled build on the dosbox homepage for people can't
or don't want to compile the sources themselves. Where's the problem
with that one?
Reply 5 of 131, by franpa
i want a build optimized for my CPU.
my website
Reply 6 of 131, by Qbix
Rank DOSBox Author
DOSBox Author
read the install file.
(and on the wiki there is some talk about how to build your own version of dosbox as well)
Water flows down the stream
Reply 7 of 131, by wd
Rank DOSBox Author
DOSBox Author
Don't expect too much from that though. Some majour parts are dynamically
generated so the compiler optimizations don't kick in.
Anyways, do you have mingw or msvc set up? If so, are all libraries installed?
That wiki page gives step by step instructions. If you're using the sources
directly from sf cvs you have to execute ./autogen.sh (mingw assumed)
before ./configure.
Reply 8 of 131, by franpa
http://dosbox.sourceforge.net/wiki/index.php? … =BuildingDOSBox
http://prdownloads.sf.net/mingw/
which msvc do i get? i got the core one... do i need any others? (that link doesnt elaborate... it just says get msvc.
also, after i install msvc and it says it found my mingw install if i try to run the msvc.bat file it says file not found instead of a unix style command prompt.
my website
Reply 9 of 131, by wd
Rank DOSBox Author
DOSBox Author
msvc!=mingw
Go to http://www.mingw.org/download.shtml
and get msysDTK-1.0.0.exe and MinGW-3.1.0-1.exe and
follow their instructions (don't remember which one has
to be installed first).
Reply 10 of 131, by franpa
this ./ thing does nothing no matter what i do, to me it sounds like this ./ is not for windows... i am linked to 2 places to get mingw and msys from... the wiki and wd.
i installed mingw then overwrote that install with msys. i setup a path to the bin folder in there. i go to dosbox 0.70 source and type via a bat file "./configure" i get a " '.' is not recognized as an internal or external command, operable program or batch file" error
do i do "make ./configure" ?
my website
Reply 11 of 131, by gulikoza
msys needs to be installed into seperate directory, not overwrite mingw (I install it to c:\mingw\msys though). At the end of msys setup, there are a few questions (like setting up path to mingw) make sure those are all ok. Then you need to run ./configure from msys, not a dos window.
http://www.si-gamer.net/gulikoza
Reply 12 of 131, by franpa
ah, ok... that is not explained on that wiki site.
my website
Reply 13 of 131, by franpa
i downloaded the msys 1.0.0 dtk and none of the exe files will run due to a lack of msys-1.0.dll
i also tried the newer 1.0.1 dtk but it exhibited the same problem... also how do i configure its paths?
http://prdownloads.sf.net/mingw/msysDTK-1.0.1.exe?download
http://prdownloads.sf.net/mingw/msysDTK-1.0.0.exe?download
my website
Reply 14 of 131, by gulikoza
You also need MSYS, install it before DTK. And if you update the wiki with the missing steps, I'm sure everybody will appreciate it 😀
Reply 15 of 131, by franpa
OK, i now at the msys prompt... er, whats the equivalent of DIR and CD FOLDERNAME and going up a level ?
location of the source is @ E:\emulators\Super Nintendo\snes tools\dosbox-0.70
my website
Reply 16 of 131, by gulikoza
At my place (msys installed in c:\mingw\msys) it's C:\MinGW\msys\1.0\home\username\
It's best to put the sources here.
(dir == ls (or ls -la), cd is the same, but needs a space for cd .. 😀)
Reply 17 of 131, by franpa
hurrah, ./configure actually does something 😁
my website
Reply 18 of 131, by franpa
checking for sdl-config... no
checking for SDL - version >= 1.2.0... no
*** The sdl-config script installed by SDL could not be found
*** If SDL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the SDL_CONFIG environment variable to the
*** full path to sdl-config.
configure: error: *** SDL version 1.2.0 not found!
where do i place the 2 sdl dll files from the dosbox for it to compile?
my website
