First post, by Sephiroth
- Member
I have recently released a frontend for DOSBox which fully supports 0.70. It even includes multiplayer setup for all three types of connections (IPX, Modem, Null-modem) and makes things very simple for the inexperienced user. It's a point-and-click GUI for Win32 and it stores all of it's settings in an INI file instead of the registry.
Now, the program has been used with my friends and I for ages, hence it being "released" as v1.0.1.11. It has gone through many UI and core-level changes to support DOSBox features over time. It even creates a default configuration for most of the DOS games that I own and can install and test, although I have not tried them all at this time.
The file is attached below as a ZIP. Included with the ZIP is a setup executable and MSI file. Run either one depending on your preference, but the executable will check for dependencies prior to running the MSI file. It weighs in at about 1.61MB. I drop by the forums on and off, so if you have a question, PM me. Most of the options are self-explanatory though, and you can always open the INI file in Notepad or Wordpad to see how they work. Oh, and if you screw the INI up, you can always delete it so the program will create a new default. Enjoy!
486 Launcher v2.0 is now under development!
