NEW TO DOSBOX NEED HELP
First post, by mutantcamel
Hi I've just downloaded this emualtor, I've read the faq's but am still stuck. When the 2 screens come up after loading the program, there is no cursor to type in "install". The one where I assume you type in commands is just blank.
Can you just go into it from your start menu or do have to go into DOS? I have Windows ME which doesn't have proper DOS.
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
read the documentation or a tutorial in the dosbox guides forum.
Topic closed
Water flows down the stream
