First post, by lwc
What is it good for?
Thanks!
Reply 1 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It is a serial port with nothing connected to it.
1+1=10
Reply 2 of 7, by lwc
I assumed that much, but what is it good for?
Reply 3 of 7, by DosFreak
Well most PC's had 2 COM ports with nothing connected to them. They are set to "dummy" in DosBox most likely for compatibility reasons for programs that expect a serial port to exist but do not necessarily need to use them.
Make your games work offline
Reply 4 of 7, by lwc
So first Y2K and now failing if the PC has less than 2 COM ports. What will we do with these 1980's/1990's programmers?
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
Nothing because they don't do that anymore. They didn't expect their
stuff to be run that long.
Reply 6 of 7, by lwc
Escuse me? I'm talking about WORSE PCs than what they expected. As in only 0 or 1 COM ports.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
They aren't worse but were back then highly unlikely. Thus the assumption was fine.
