new dosbox
First post, by abyss
Can the new dosbox run windows 98,windows 1.x and 2.x. I highly doubt it can run windows 95. I am just wondering as i am not getting windows 1.x,2.x and windows 9.x
Reply 2 of 3, by DosFreak
It can run Windows 95 but it is not officially supported and you will encounter errors while using it.
Just use Qemu/VirtualBox/VPC if you want to run those Windows versions.
Make your games work offline
Reply 3 of 3, by wd
Rank DOSBox Author
DOSBox Author
2.x should run (cripple the returned dos version)
