how to
First post, by abyss
http://www.youtube.com/watch?v=B1PsiOlIw7Q
It's a manual on how to use dosbox. You can tell it is missing some important info but it is still good advice on using dosbox. To run doom you should follow my advice. use dosbox 0.70 and go into fullscreen by pushing alt,enter now run doom which on my computer i would have to mount d d:/jeff/games/doom
d:
know type doom and go to 9000 cycles by using ctrl f12. I have a 500 mhz machine so the reccomended cycles may be different on your machine.
Reply 1 of 10, by leileilol
6 minutes only to get DOOM working? Jeez. Anyone can just start Doom in dosbox 0.70 just by
cd doom
doom
no fooling with config or ctrl-f12ing since protected modes get auto'd core and cycles for maximum performance.
also wtf 500MHz?
long live PCem
Reply 2 of 10, by DosFreak
heh. Heretic. That was funny.
Why is he not using a port? (I guess just to demonstrate DosBox...although he doesn't mention a port)
Winzip? 🤣. Wonder if he's using the registered ver?
Frame rate is 3000?
He messes up on configuring the sound.
Make your games work offline
Reply 3 of 10, by abyss
what is wrong with a 500 mhz computer. Whats wrong with using 9000 cycles and dynamic mode to run doom. What is wrong with his sound configurations on doom except he did not use pc speaker.
Reply 4 of 10, by leileilol
abyss wrote:
what is wrong with a 500 mhz computer. .
The year is 2007. The average computer speed is 2500MHz. You figure the rest out.
long live PCem
Reply 5 of 10, by DosFreak
MiniMax, this AI is very very weird.
Hmmm, let's test:
Round Windows Linux OSX SADDAM OS/2 MAC Apple Nintendo SPAM Viagra Princess Diana Elvis JFK Moon NASA.
Hmmm, now we'll see.....
Reply 6 of 10, by abyss
Should i use the 2.66 ghz machine instead. I made a mistake on my computer configurations i originally thought the 500 mhz computer was 1.3 ghz. 500 mhz still does the job. Especially when you have a good vesa compliant video card.
http://www.youtube.com/watch?v=4C8LJXK98DY
A grand prix 2 video running in dosbox 0.70. I am surprised on how playable the game is on a 486.
Reply 8 of 10, by abyss
Whats the minimum requirements to run quake with dosbox.
Reply 9 of 10, by leileilol
obviously alot more than 500mhz 🙄
long live PCem
Reply 10 of 10, by abyss
I can go up to a little over 30 thousand cycles is that enough to play quake. You made a mistake setting up doom you did not choose pc speaker.
Edit: I remember playing quake with somewhere around 30 thousand cycles and 10 framskip on dosbox 0.65 and getting playable performance. I did not get sound though. It was a bit slow but it was playing at a more than playable speed. It was playing just like when i originally played quake on a older computer except their was no sound. I was in dynamic mode and all the memory options were on and had 32 megabytes instead of 64 megabytes on.
