First post, by Rombs
Several games I have tried to install (ej. Privateer 2, amongst others), required (in DOS times) that information be included in the Config.Sys file for DOS (for example, the classic Files=XX Buffer=XX and such data).
Is there an equivalent to the Config.sys file in Dosbox? If not, how do you overcome these issues?
Thank you.
AR.
Reply 1 of 2, by frobme
For stuff like FILES= or BUFFERS=, you don't have to worry about it with DosBox. The provided emulated DOS environment won't fail on allocating these resources the way DOS did back in the day.
-Frob
Reply 2 of 2, by kruwi
If it does not work for some games anyway (very rare) you can create a dummy config.sys file and just insert the desired values into this dummy file. This may work, at least it is worth a try. But regularly you don't have to worry about these issues.
Visit the end of the internet: www.groskreutz.de
