First post, by scatola
Hi to all, i want to able the sound in Deah Rally.
If i enable the sound from the setup, the game not start and remains a black screen. If from setup i disable the sounds, the game works perfect but without sounds (and music) 😵 can anyone help me please?
Thanks in advance 😉
Reply 1 of 16, by leileilol
Sounds like you're trying to run it directly in the horrible NTVDM. Try DOSbox out 🙁
Reply 2 of 16, by scatola
I am using Dosbox 0.70 😖
Reply 3 of 16, by wd
Rank DOSBox Author
DOSBox Author
How did you configure sound in the game?
Reply 4 of 16, by scatola
From Setup, i try use both:
-Sound Blaster MONO/PRO/AWE32: 0x210, IRQ 7, DMA Channel 0
and
-Sound Blaster MONO/PRO Compatibe: 0x210, IRQ 7, DMA Channel 0
But if i enable the sound, the game remains a black screen.
Reply 5 of 16, by wd
Rank DOSBox Author
DOSBox Author
address=220 irq=7 dma=1 should work
Reply 6 of 16, by scatola
OH THANKS!!!! REAL WORKS!!! 🤣 😀 😀
Reply 7 of 16, by scatola
Hey wd, i'm unable to create a multiplayer game.
Have u tryed this play mode?
I think is impossible create because this is a old game and is not compatible with recents systems
Reply 8 of 16, by wd
Rank DOSBox Author
DOSBox Author
I don't have the game, so no idea. But look through the dosbox readme,
there's a section about network/multiplayer gaming.
Reply 9 of 16, by scatola
ok, thanks.
The last question: can i add the vsync to Death Rally?
Reply 10 of 16, by wd
Rank DOSBox Author
DOSBox Author
what?
Reply 11 of 16, by eL_PuSHeR
Ykhwong's builds have some sort of VSYNC control.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 12 of 16, by scatola
Vsync= Vertical Sync
Thanks eL_PuSHeR! The game run better and duryng the game, my resolution remains the desktop resolution 😀
Reply 13 of 16, by wd
Rank DOSBox Author
DOSBox Author
Um i know what vsync is, but the sentence "can i add the vsync to Death Rally?"
didn't make any sense to me.
Reply 14 of 16, by eL_PuSHeR
I prefer to control VSYNC via graphic driver control panel. In fact, I have it always enabled for my ATi card.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 15 of 16, by scatola
Sotty wd, but i am italian and i write this language poor.
Reply 16 of 16, by wd
Rank DOSBox Author
DOSBox Author
No problem, just write longer sentences 😀
