First post, by eL_PuSHeR
Rank Moderator
Moderator
I can't seem to run this game anymore although I recall having run it once. It gives me a runtime error: divide by zero error using the NTVDM and, using DOSBox (both official 0.70 and latest Ykhwong's) the game start and I can configure graphics, sound, etc, but it kicks me back to the DOSBox prompt when I press start. Anyone?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 1 of 2, by Og
I just tried to run this game and also had the same results as you(only with 0.72), I tried to change many options in the config file, even tried setting machine to Tandy, all to no avail.
The game DOES run if I boot MS-DOS v6.22 inside DOSBox though...
Reply 2 of 2, by eL_PuSHeR
Rank Moderator
Moderator
I am starting to think that something is broken inside the code of this game. It is very difficult to run, when it shouldn't be.
Intel i7 5960X
8 GB DDR4 (2100)
