First post, by fidodido
I've created a batch file with all the commands to run a game, and I want to copy it to the main directory of DOSBOX (the default z:\ directory where the files command.com and autoexec.bat and the rest of the system files are located), so I won't have to write all the commands every single time. How can I do that?
Thanks.
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
You don't, but have a look at the [autoexec] section of dosbox.conf,
there you can put the content of your batch file.
Reply 2 of 2, by fidodido
Thanks. It served my purpose. 😀
