old demo scene stuff?
First post, by Unregistered
Has anyone been able to get any old demo scene demos to run with sound in winXP? Stuff like "Second Reality" or "Fatcs of life".
X.
Reply 1 of 8, by Harekiet
Rank DOSBox Author
DOSBox Author
They normally need very accurate timing, which windows XP doesn't provide. Second reality runs seriously slow here anyway 😀
Reply 2 of 8, by vladr
SPEEDSET may easily solve that... provided that someone who is confortable with p-mode know how to adapt it for that (the main problem is that the ISR no longer gets called once progs enter p-mode, I guess because the set of vectors is switched for the task, so it gets complicated since the TSR ISR is real-mode).
Cheers,
V.
Reply 3 of 8, by Nicht Sehr Gut
Originally posted by Unregistered Has anyone been able to get any old demo scene demos to run with sound in winXP? Stuff like "Second Reality" or "Fatcs of life".
Outside of a full-fledged "PC Emulator", I wouldn't expect many "classic" DOS demos to work properly on modern systems.
Way too many "hit the hardware"...really hard.
One good bit of news, for those that do run on an NT OS, there's a chance that GusEmuwill give you beautiful GUS audio to go with it.
Reply 4 of 8, by Schadenfreude
Cheers,
V.
I hope that someday some programmer takes up the challenge...
Reply 5 of 8, by Harekiet
Rank DOSBox Author
DOSBox Author
The realmode interrupt service doesn't get called anymore under pmode if the pmode program tries to at least save some speed 😀
Reply 6 of 8, by HunterZ
Oh man. I never had a GUS, but they should merge that project into VDMSound and/or DOSbox.
Reply 7 of 8, by Nicht Sehr Gut
Originally posted by HunterZ Oh man. I never had a GUS, but they should merge that project into VDMSound and/or DOSbox.
*heh*
showthread.php?threadid=187&highlight=GUS
showthread.php?threadid=719&highlight=GUS
You're welcome to "carry on the fight". At least the author is still making minor changes (last was on 7 March, 2003).
Reply 8 of 8, by Snover
But I'd roll all the patches and updates into VDMSound 2.05 first, if I were you.
Quoth Stiletto in NOVEMBER OF 2002. *heh*
Yes, it’s my fault.
