Hello me again
I checked my log:
@I - 00:03:52.849 - VDMServicesProvider
VDMServices initialized (hInstance = 0x02990000)
@I - 00:03:52.851 - SysExIndicator
ActivityLights initialized
@I - 00:03:52.863 - MIDIPlayer
MIDIOut initialized (device ID = 2, 'Creative Sound Blaster MPU-401')
@I - 00:03:52.864 - DMATransferManager
Transfer Manager thread created (handle = 0x0000017c, ID = 3580)
TransferMgr initialized (minPeriod = 2ms, maxPeriod = 10ms)
@I - 00:03:52.870 - SBWavePlayer
Garbage collector thread created (handle = 0x0000018c, ID = 3584)
@I - 00:03:52.871 - SBWavePlayer
WaveOut initialized (device ID = -1, 'Primary Sound Driver / ')
@W - 00:03:52.872 - SBController
Could not obtain the dependency 'AdLib'; using a default value
instead. Description follows:
0x80004004 - Operation aborted
Could not locate the dependency reference 'AdLib' in either of the
[SBController.depends] or [*.depends] INI sections (see
C:\DOCUME~1\Nick\LOCALS~1\Temp\~VLP6381.INI:49).
@I - 00:03:52.873 - DMATransferManager
DMA processing rate recovered to its normal value (upper bound =
10ms, last period = 10.00ms, current period = 10.00ms
@I - 00:03:52.873 - SBController
SBCompatCtl initialized (DSP version = 4.05, base port = 0x220, IRQ =
7, 8-bit DMA = 1, 16-bit DMA = 5)
@I - 00:03:52.874 - MPU401Controller
MPU401Ctl initialized (base port = 0x330, IRQ = 2)
@I - 00:03:53.013 - MIDIPlayer
Garbage collector thread created (handle = 0x00000174, ID = 3576)
@I - 00:01:12.597 - VDMServicesProvider
@I - 00:01:12.650 - SysExIndicator
@I - 00:01:12.780 - MIDIPlayer
@I - 00:01:12.805 - MIDIPlayer
Garbage collector thread created (handle = 0x00000174, ID = 2848)
@I - 00:01:12.808 - DMATransferManager
Transfer Manager thread created (handle = 0x00000184, ID = 2852)
@I - 00:01:12.811 - DMATransferManager
@I - 00:01:12.864 - SBWavePlayer
Garbage collector thread created (handle = 0x00000194, ID = 2856)
@I - 00:01:12.867 - SBWavePlayer
@W - 00:01:12.919 - SBController
C:\DOCUME~1\Nick\LOCALS~1\Temp\~VLP6AA2.INI:49).
@I - 00:01:12.925 - DMATransferManager
@I - 00:01:12.928 - SBController
@I - 00:01:12.952 - MPU401Controller
@I - 00:01:13.569 - VDMServicesProvider
Created DOS process (0x051a, 'C:\WINNT\System32\KB16.COM')
@I - 00:01:13.696 - VDMServicesProvider
Created DOS process (0x0698, 'E:\1\AIROS.EXE')
@I - 00:01:15.534 - SBController
DSP reset - reinitializing DSP
@W - 00:01:15.538 - SBController
Attempted to read from write-only port (IN 0x226)
@W - 00:01:15.541 - SBController
@W - 00:01:15.544 - SBController
@W - 00:01:15.548 - SBController
@W - 00:01:15.551 - SBController
@W - 00:01:15.554 - SBController
@W - 00:01:15.558 - SBController
@W - 00:01:15.561 - SBController
@W - 00:01:15.615 - SBController
@W - 00:01:15.618 - SBController
@W - 00:01:15.672 - SBController
@W - 00:01:15.726 - SBController
@W - 00:01:15.730 - SBController
@W - 00:01:15.734 - SBController
@W - 00:01:15.738 - SBController
@W - 00:01:15.743 - SBController
@W - 00:01:15.748 - SBController
@W - 00:01:15.752 - SBController
@W - 00:01:15.756 - SBController
@W - 00:01:15.760 - SBController
@I - 00:01:15.765 - SBController
startTransfer: Starting DMA transfer (playback) on ch. 5
(single-cycle, 1 samples/block): 16-bit stereo 22050Hz, signed PCM
@I - 00:01:15.851 - SBWavePlayer
DirectSound primary buffer format is currently set to 44100Hz 16-bit
stereo
@I - 00:01:15.856 - SBController
HandleAfterTransfer: Interrupting (16-bit, x2) after 91ms, 4 bytes
(terminal count)
@I - 00:01:15.967 - SBController
IRQ acknowledged (16-bit)
@I - 00:01:28.840 - SBController
startTransfer: Starting DMA transfer (playback) on ch. 1 (auto-init,
2048 samples/block): 8-bit mono 22050Hz, unsigned PCM
@I - 00:01:28.885 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 45ms, 2048 bytes
@I - 00:01:28.889 - SBController
IRQ acknowledged (8-bit)
@I - 00:01:28.970 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 130ms, 4096 bytes
(terminal count)
@I - 00:01:28.974 - SBController
@I - 00:01:29.054 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 214ms, 6144 bytes
@I - 00:01:29.058 - SBController
@I - 00:01:29.138 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 298ms, 8192 bytes
(terminal count)
@I - 00:01:29.142 - SBController
@I - 00:01:29.223 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 383ms, 10240
bytes
@I - 00:01:29.227 - SBController
@I - 00:01:29.307 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 467ms, 12288
bytes (terminal count)
@I - 00:01:29.311 - SBController
@I - 00:01:29.391 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 551ms, 14336
bytes
@I - 00:01:29.397 - SBController
@I - 00:01:29.475 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 635ms, 16384
@I - 00:01:29.479 - SBController
@I - 00:01:29.560 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 720ms, 18432
bytes
@I - 00:01:29.564 - SBController
@I - 00:01:29.644 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 804ms, 20480
@I - 00:01:29.648 - SBController
@W - 00:01:29.831 - SBController
HandleTransfer: DMA updates too infrequent (unable to keep up with
desired transfer rate), requesting boost
@I - 00:01:30.697 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 1856ms, 22528
bytes
@I - 00:01:30.701 - DMATransferManager
Boosting DMA processing rate by 30.0% at DMA handler's request
(period decreased from 10.00ms to 7.69ms), post-boost recovery rate
updated to 0.077%
@I - 00:01:30.731 - SBController
@W - 00:01:30.733 - SBController
@I - 00:01:30.746 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 1906ms, 24576
@I - 00:01:30.750 - DMATransferManager
(period decreased from 7.71ms to 5.93ms), post-boost recovery rate
updated to 0.059%
@I - 00:01:30.755 - SBController
@I - 00:01:30.791 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 1951ms, 26624
bytes
@I - 00:01:30.795 - SBController
@I - 00:01:30.884 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2044ms, 28672
@I - 00:01:30.888 - SBController
@I - 00:01:30.978 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2138ms, 30720
bytes
@I - 00:01:30.982 - SBController
@I - 00:01:31.072 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2232ms, 32768
@I - 00:01:31.088 - SBController
@I - 00:01:31.167 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2327ms, 34816
bytes
@I - 00:01:31.171 - SBController
@I - 00:01:31.261 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2421ms, 36864
@I - 00:01:31.277 - SBController
@I - 00:01:31.355 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2515ms, 38912
bytes
@I - 00:01:31.359 - SBController
@I - 00:01:31.450 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2610ms, 40960
@I - 00:01:31.466 - SBController
@I - 00:01:31.544 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2704ms, 43008
bytes
@I - 00:01:31.548 - SBController
@I - 00:01:31.632 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 2792ms, 45056
@I - 00:01:31.636 - SBController
@I - 00:01:32.683 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 3843ms, 47104
bytes
@I - 00:01:32.726 - SBController
@W - 00:01:32.730 - SBController
@I - 00:01:32.734 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 3894ms, 49152
@I - 00:01:32.739 - DMATransferManager
(period decreased from 6.53ms to 5.03ms), post-boost recovery rate
updated to 0.050%
@I - 00:01:32.756 - SBController
@I - 00:01:32.788 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 3948ms, 51200
bytes
@I - 00:01:32.792 - SBController
@I - 00:01:32.877 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4037ms, 53248
@I - 00:01:32.885 - SBController
@I - 00:01:32.966 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4126ms, 55296
bytes
@I - 00:01:32.970 - SBController
@I - 00:01:33.056 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4216ms, 57344
@I - 00:01:33.060 - SBController
@I - 00:01:33.150 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4310ms, 59392
bytes
@I - 00:01:33.154 - SBController
@I - 00:01:33.244 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4404ms, 61440
@I - 00:01:33.248 - SBController
@I - 00:01:33.339 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4499ms, 63488
bytes
@I - 00:01:33.343 - SBController
@I - 00:01:33.433 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4593ms, 65536
@I - 00:01:33.437 - SBController
@I - 00:01:33.525 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4685ms, 67584
bytes
@I - 00:01:33.529 - SBController
@I - 00:01:33.615 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4775ms, 69632
@I - 00:01:33.619 - SBController
@I - 00:01:33.709 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 4869ms, 71680
bytes
@I - 00:01:33.713 - SBController
@W - 00:01:33.869 - SBController
@I - 00:01:34.653 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 5813ms, 73728
@I - 00:01:34.657 - DMATransferManager
(period decreased from 5.54ms to 4.26ms), post-boost recovery rate
updated to 0.043%
@I - 00:01:34.698 - SBController
@W - 00:01:34.701 - SBController
@I - 00:01:34.706 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 5866ms, 75776
bytes
@I - 00:01:34.711 - DMATransferManager
(period decreased from 4.28ms to 3.29ms), post-boost recovery rate
updated to 0.033%
@I - 00:01:34.740 - SBController
@I - 00:01:34.745 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 5905ms, 77824
@I - 00:01:34.749 - SBController
@I - 00:01:34.833 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 5993ms, 79872
bytes
@I - 00:01:34.837 - SBController
@I - 00:01:34.922 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6082ms, 81920
@I - 00:01:35.014 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6174ms, 83968
bytes
@I - 00:01:35.018 - SBController
@I - 00:01:35.105 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6265ms, 86016
@I - 00:01:35.112 - SBController
@I - 00:01:35.197 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6357ms, 88064
bytes
@I - 00:01:35.205 - SBController
@I - 00:01:35.291 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6451ms, 90112
@I - 00:01:35.295 - SBController
@I - 00:01:35.382 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6542ms, 92160
bytes
@I - 00:01:35.386 - SBController
@I - 00:01:35.473 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6633ms, 94208
@I - 00:01:35.477 - SBController
@I - 00:01:35.565 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6725ms, 96256
bytes
@I - 00:01:35.569 - SBController
@I - 00:01:35.659 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 6819ms, 98304
@I - 00:01:35.663 - SBController
@I - 00:01:37.300 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8459ms, 100352
bytes
@I - 00:01:37.322 - SBController
@W - 00:01:37.325 - SBController
@I - 00:01:37.330 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8490ms, 102400
@I - 00:01:37.335 - DMATransferManager
(period decreased from 3.67ms to 2.82ms), post-boost recovery rate
updated to 0.028%
@I - 00:01:37.339 - SBController
@I - 00:01:37.384 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8544ms, 104448
bytes
@I - 00:01:37.388 - SBController
@I - 00:01:37.460 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8620ms, 106496
@I - 00:01:37.465 - SBController
@I - 00:01:37.540 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8700ms, 108544
bytes
@I - 00:01:37.544 - SBController
@I - 00:01:37.624 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8784ms, 110592
@I - 00:01:37.635 - SBController
@I - 00:01:37.713 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 8873ms, 112640
bytes
@I - 00:01:37.717 - SBController
@W - 00:01:37.881 - SBController
@I - 00:01:44.779 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 15939ms, 114688
@W - 00:01:44.784 - DMATransferManager
Unable to further boost DMA processing rate, lower bound already met
(lower bound = 2ms, last period = 2.99ms, current period = 2.30ms
@I - 00:01:46.458 - SBController
@W - 00:01:46.460 - SBController
@I - 00:01:46.468 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 17628ms, 116736
bytes
@I - 00:01:46.472 - SBController
@I - 00:01:46.518 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 17678ms, 118784
@I - 00:01:46.524 - SBController
@I - 00:01:46.594 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 17754ms, 120832
bytes
@I - 00:01:46.598 - SBController
@I - 00:01:46.677 - SBController
HandleAfterTransfer: Interrupting (8-bit, x1) after 17837ms, 122880
@I - 00:01:46.681 - SBController
Can anyone help?
