First post, by Iverindor
Where is Jon? I enormously like his work and I wonder whether it works with U.B. as it claimed.
Reply 2 of 3, by JC
Hi! I've been very busy with other projects and haven't had the time to do much of anything on this. I did get as far as mapping textures from the packs I have released across to UB, so I will attach this here as a 'work-in-progress'. There are no new textures here, just mapping files and an updated equiv file - If you unzip it and drop it on top of your Glidos/Textures folder it should add the necessary stuff to the JC folder for you to be able to play a reasonably retextured UB!
    JC.zip
    118.45 KiB
    566 downloads
