First post, by lilblu
I downloaded a game called Micro Machines V3 that came in a zip file about 60 MB. In that zip file there are 44 other zip files that are about 1.39 MB each. Some of the folders have files that have the same name and same size. Some of these files are:
mw.nfo
ss.nfo
file_id.diz
I opened the razor.nfo file and it said:
Install: Unzip it. Unace it (xace MMV3.ACE <your directory>), then
import the MMV3.REG file by double clicking on it.
To configure the controls run MM3JOY.EXE,
to use the character import/export part run MM3IO.EXE,
to play the software rendered version run INTROS.EXE
and to play the hardware rendered version run INTRO.EXE.....
My advice is to run MM3JOY.EXE first, makes playing it alot less of a pain
Am I supposed to extract the zip files to their own folder or to a main folder? Since some of them have the same name, they would have to be overwritten if extracted to a main folder.
Also, there is a xace.exe file that came with it that was created in 1998 and is about 83.5 KB. I assume this is the file I'm supposed to use to uncompress the .ACE files. Is this xace.exe a command line/dos uncompressor?
Reply 1 of 3, by leileilol
no. This XACE.EXE file is a sign that you sir need to go out and buy the game instead of asking us for warez advice.
Original copies prevail.
long live PCem
Reply 2 of 3, by lilblu
Sorry. I wasn't aware this game could be purchased anywhere. I thought it was one of those ones that aren't being sold anymore (abandonware). If you know where I can purchase it, please let me know. And if a moderator thinks my original post should be deleted, please do so.
Reply 3 of 3, by eL_PuSHeR
Warez/Abandonwarez and the such isn't allowed here in any way.
Sorry, lilblu.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
