Serial port error!
First post, by siraj
I have got a P4 machine with XP service pack2
I installed dosbox 0.7 and want to use this for accessing operation and maintenance terminal who use a com1 port
here are my config file setting for serial port.
serial1=directserial realport:com1 startbps:9600 parity:none bytesize:8 stopbits:1 irq:4
serial2=dummy
serial3=disabled
serial4=disabled.
and here are the error i get.
DOS box status windows.
config: loading primary setting form config file c:\program files\dossbox-0.70\...
sbox.config
midi:opened device:win32
serial1: opening com1
serial1: serial port "com1" could not be opened.
the specified port is already in use.
please help me to get out of this.
thanks.
Reply 1 of 2, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Well some other application is using your COM1. Close it and try again.
1+1=10
Reply 2 of 2, by siraj
thanks anyway.
i have tried the same setting in my laptop with USB to com port cable and it worked. thanks.
i will appriciate DOSbox is a very good software.
