First post, by ArchiveoftheDead
Here's what I get once I try to play the original rayman in DosBox:
What do I do?
What do I do?
And when I run Rayman Designer, all I can get is a limited version without background music. How do I fix this?
did you mount the cdrom properly? did you mount the D: drive?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
_________________
Hello, I am having the same problem with Rayman from the rayman forever version. I know it mounted it properly because it worked the first time. But the game froze and I had to restart and since have not been able to play again.
Has there been a solution to this problem?
Thanks!
Sorry, I just solved it. i mounted the actual cd and then opened from the c drive. Thanks!
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
