Serial port
First post, by IlConte1
Dear 🙁
I ahve a old DOS application that work with serial port.
The application works does not work well because the serial port is write and read directly by interrupt.
I have look in the source that the serial port is read by polling and this is a timing problem.
Moreover my serial protocol use the nine-bit synchronization and dosbos some time don't recognize correctly the nine-bit (parity).
There is a plug-in o other solution for work with serial at low level ?
Thank all in advance
Stefano
Reply 1 of 1, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Parity detection is done in the hardware, not in DOSBox. Some USB/Serial adaptors can cause problems.
Don't think so.
1+1=10
