Discworld 1 Win2k
First post, by VippiN
Opening DWB.EXE or DISC.BAT using VDMS makes zero change to the game, no sound at all. I checked past threads and it gave no help.
Suggestions?
Reply 1 of 8, by vladr
Suggestions?
You wouldn't happen to be using a CD-rip of the game, would you?
~vladr/list.php?appid=269
~vladr/list.php?appid=30
Reply 2 of 8, by Unregistered
No, I am using a bought version. Haven't touched it since my old 200MHZ machine on Win95.
Reply 3 of 8, by Unregistered
Ah, the second link however fixed my problem! Thank you.
One last thing, can you run the game in a window instead of full screened?
Reply 4 of 8, by DRECK
NOPE. NO you can not!
In WinXP you can not run DOS-Games in a WINDOW!
I believe that all NT-based Windows NT/2000/XP cannot run DOS-GAMES in a WINDOW!
Test it! First check your VDMS-Shortcut file or pif-File of Discworld: The Windows-Shortcut "ALT+ENTER" must be enabeld.
Then start Discworld: press "ALT+ENTER" then you can see if it works or not!
With simple graphic/text-modes the screen/windows-switching works.
Test it. Start a "Dos-BOX" C:\ and press "ALT+ENTER"
Reply 5 of 8, by Unregistered
Unfortunately I had already tried Alt+Enter and it freezes the game, going back full screen unfreezes it.
Reply 6 of 8, by Schadenfreude
SciTech Display Doctor wants to write a program that lets you run games in a window in NT/2000/XP, but so far they've been stymied.
I hear they want all games crashing problems fixed in NTVDM before trying to make it. *LOL*
Reply 7 of 8, by Nicht Sehr Gut
Originally posted by DRECK In WinXP you can not run DOS-Games in a WINDOW
The only way it can be done is with a full PC-emulator like "Virtual PC" or Bochs.
Reply 8 of 8, by Guest
It's VippiN again after a year or more. Same problem! Link no longer seems to work. Help?
