Copy Failure
First post, by Shadow_Orion
I tried to load Privateer wing commander through dosbox but it said copy failure for some of the files, so i tried to copy them directly instead of going through the install and it still says copy failure, the files are Priv.tre and rf.tre, I have the original versions from origin, together on the same disc (Rightous Fire and Privateer) I am running Windows Vista as my OS (which is prob. my first mistake) Why didn't I invest in an I Mac? on a Dell Dim. C521 also I checked the status and it says that the file creation failed for some reason. I`m not that good with computer language or even what I`m doing so any help would be good.
Reply 1 of 2, by DosFreak
Is this a CD? If so try copying them off of the CD in Windows onto your hard drive without using DosBox.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 2, by Shadow_Orion
yes its on a cd but I copied it directly from the cd to windows but windows is insisting that it wasn`t installed correctly and it won`t work in DosBox when I try to locate the file it says unable to change to privater. I have no idea whats going on.
