First post, by Fallout
First I installed VDMSound 2.1 with full installation. Than restart the PC. Than I installed it with TR advanced installer with glidos. The error message:
"VDMS Launchpad - Tomb Raider
NTVDM CPU ...... (i can not translate)
CS:001a IP:01 dc OP:8f 16 44 03 7f To finish the process press close."
Than I intalled "TrAndUbForGlidos.exe" and it works for glidos! (but it requires an activation to play so I must play with dgvoodoo or play with bad graphics)
When i intalled with dgvoodoo 1.40+ or 1.31 i got the same message. After installing the patch "TrAndUbForGlidos.exe", the game seems like to start but all I get is a black screen.
When I tried with non of them (glidos or dgvoodoo) the same message appears and after insttaling the same patch, the same fact occurs.
Please find a way to get it working.
Sorry my poor english...
My PC specs:
P4 3.0@3.6
7600 GT (nvodngov19792 driver)
Audigy 2 ZS (Audigy 4 modded)
2 GB ram (2*512+1)
Reply 1 of 1, by ADDiCT
I've tried running TR with the dgVoodoo/VDMSound and Glidos/VDMSound combos, but had nothing but trouble. The game just didn't work.
Now i'm using yhkwong's build with GLIDE support enabled, and TR runs perfectly fine. You have to use the Voodoo Rush executable, not the 3DFX one.
