First post, by abyss
abyss
Offline
Is it possible to get a runtime error in dosbox?
abyss - what is a runtime error?
_________________
yes it is possible.
dos games can get runtime errors inside dosbox. For example when they can't find a file.
Water flows down the stream
And if you mean the "runtime error 200" that occurs because of a badly conceived timing routine in Turbo Pascal programs, yes, that is possible, if the cycles are set too high.
My site: Ramblings on mostly tech stuff.
