First post, by jsnowd02
Im new to the retro gaming scene. Yesterday i got a hold of a copy of Tomb Raider I and installed it on my laptop, along with glidos. i was so pleased with the results i payed the $10 for the registered version. Everything was going well, and i called it quits last night half way through St. Francis's Folly, and shut down my computer. This morning when i tried to play again, lo and behold, the logo was back.
Now i understand that i can use the unlock feature more than once, but is this going to happen everytime i shutdown my computer? Before you ask, no i did not make any hardware changes. Im puzzled, but then again alot of things puzzle me... hope someone can offer some advise.
I apologise if this issue has been dealt with in a previous post, feel free to direct me there instead.
Cheers
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
I wouldn't worry too much jsnowd02. Paul (the author of GliDOS) is always very helpful in these matters. If this problem re-occurs, I think he will send you a small test-program you need to run after re-booting. That program will help him determine why the checks fails to recognize your laptop.
_________________
Reply 2 of 3, by Glidos
Yeah, I'll make sure you are ok.
There were some known problems like this with Vista, but I thought I'd fixed those.
There's also a known problem with network changes: e.g., if you sometimes have yout modem switched off, or you have a laptop sometimes plugged into a network, sometimes not.
Reply 3 of 3, by jsnowd02
Ok, thanks guys... i unlocked glidos again, and all seems to be working ok. I use XP, so vista is not the issue. i am on a wireless LAN, so maybe its network hardware related, im not sure... anyway thanks for your time, il be back if i have any more trouble. By the way, great job, glidos is awesome.
