First post, by calamar
Hello everyone!
I'm using DOSbox 0.70 on Windows Vista and I'm having problems installing some games from CDROM.
First of all I mount source and destination folders as drives C and D:
mount c c:\sistemas\dosbox-0.70\drive
mount d e:\ -t cdrom
And when game starts to install on drive C, it seems to go quite slow on reading, when CD drive works perfectly in Windows.
Which could be the problem?
Thanks!
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
Hmm.. No idea why it is slow. Does it help if you add an -ioctl option to the mount command for the CD-ROM (I don't think it will, but you can try)?
You can also try to create an image of the CD (create a BIN/CUE image if possible) and mount the image as drive D in DOSBox:
imgmount D C:\path\to\image.cue -t iso
That should be very fast.
_________________
Reply 2 of 7, by eL_PuSHeR
WELCOME TO THE FORUM.
Just a shot in the dark. Are you using dynamic core calamar?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
-t cdrom doesn't do anything fancy. (currently)
game probably acces the files in an inefficient way.
Water flows down the stream
Reply 4 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Installers might be real-mode and thus crawl along at 3000 cycles with the default settings.
1+1=10
Reply 5 of 7, by calamar
In my dosbox.conf, this are my parameters for CPU config:
core=auto
cycles=auto
cycleup=500
cycledown=20
Maybe so low cycles? Which would be the best value for cycles?
I tried "-ioctl" option in the cdrom mount command but it's as slow as without it.
Sorry but I'm very newbie with DOSbox.
Reply 6 of 7, by Freddo
Aye, some installers go much more quickly if you use higher cycles.
I think the best thing to do is to create a bin/cue image of the CD and then use the IMGMOUNT to mount it. It's easy to make images with MagicDisc, which is free.
Reply 7 of 7, by eL_PuSHeR
Just type "core dynamic" and "cycles max 80%" at the DOSBox Z:\> prompt (without quotes) before running the installer. Try again.
Intel i7 5960X
8 GB DDR4 (2100)
